I would like to show you two of my Danish ship-models. The cutter is a rather heavy modified Artitec-model, while the steamship is a model from Frenchman River wich was given a Danish touch.
The cutter is based on the many pictures of ships I made during hollidays in Denmark. The steamship isn't based on a real Danish ship I've seen, but was made to look more or less Danish by the red-white-red colours around the chimney.
Please let me know what you think of it! (You can view the pictures only when you are logged in!)
Kind regards,
Gert (from Holland)
PS: I was rather shocked when I discovered last summer that most of the fish cutters at Faaborg (Fyn) are no longer there. What's happening there?
Michael BJ
Hej Gert
Det er da et par dejlige skibsmodeller du har frembragt. Det er rigtig god inspiration for os andre.
Især synes jeg at damperen er ret herlig, men jeg har dog aldrig set et skib med den placering af skorstenen før, den er ret speciel.
Fiskekutteren er også flot, men den er lidt for moderne for mig, for med det udseende hører den vist nærmest hjemme i epoke IV eller V.
Hvem laver damperen - er Frenchman River en modelfabrikant?
Michael
Dansk epoke 3
JGJ67
værktøjsmager
Det er et par fine skibe, lige tilpas til en lille havn. Mon ikke man kunne finde den slags både i de sydfynske havne...
Mvh Jesper
Thanks for your replies.
Frenchman River produces kits for boats in 1:87 and other scales.
Please have a look at their website: http://www.frenchmanriver.com/
Kind regards,
Gert (from Holland)
Hi Gert,
Nice models, I especially like the red Cutter. Your weathering at the front is very realistic (rust). The painting of the red lines around the windows in the steering cabin could have been a bit more precise and sharp. The edges are a bit blurred/uneven. A small Tip from me - how to correct that can be read in this little booklet.
Lackieren im Modellbau
All about spraying and painting all sorts of models, so if you can read German, this is a good choice, and it has a price tag of only EUR 12,00, so it is relatively cheap.
Best regards
Thanks Lars! I will try to get a copy of the book you metioned. Reading German is no problem.
Kind regards,
Min flåde vokser støt, takket være indsatsen fra en af mine bekendte. Han byggede denne vidunderlige modeller for mig.
Gert (fra Holland)
Flot, flot Gert din heldige rad
Jeg er "forelsket" i coasteren / 50.130 fra Artitex
Er der nogen der har erfaringer i at bygge den. Er det f. eks let at male på den plast der er brugt
Gert / koster den også 149,- € i Holland eller kender Du en forhandler, der er billigere
Det ser godt ud, Gert!
Det kunne måske inspirere mig til at komme igang med mine egne skibsbygningsprojekter i størrelse ca. H0 - det er byggesæt fra både Revell/Monogram, Lindberg, Airfix, Artitec, samt selvbyg.
Nogle af de "souvenir-modeller", som butikkerne ude i sommerlandet falbyder, er faktisk ret flotte, og nogle af dem passer perfekt til H0.
Jeg kunne måske vise nogle eksempler frem ? (Når jeg får fundet dem frem fra mine gemmere).
Hej Steff. Samme pris her i Holland. Her kan du finde informationer om maleriet Artitec modeller. Desværre kun på hollandsk:
http://www.artitec.nl/index.php/de/bouwen-en-schilderen-stap-voor-stap?s...
Vær så venlig!
Klarsyn
Odense N
Jeg har den liggende og skal igang med at bygge den. Jeg har tænkt mig at male den med Humbrol. Det er de farvekoder de bruger i byggevejledningen, så det vil jeg tro virker.
Hilsen Morten
Besøg min blog på: http://www.sporskiftet.dk/blogs/klarsyn og læs mere om mit anlæg.
tybalt
It-projektleder
Nu ved jeg ikke hvor store jeres erfaringer er med bygning i resin men Steff spurgte ind til mulighederne for at male på det. Her er mine erfaringer: Resin er et stift materiale og samles bedst med "superlim", jeg bruger helst en på gel-form fra Hobbydillen. Men efter at have lakeret mange resinoverdele har jeg erfaret at man næsten ikke kan være omhyggelig nok med at rengøre overfladen før maling. Sagen er den at man ved støbningen bruger et slipmiddel i formene der får maling til at skalle af. Jeg starter med at rense med skurepulver og en opvaskebørste/skuresvamp og afslutter med at vaske det hele i grundrens. Efter en aftørring med køkkenrulle og lufttørring på radiator går modellen direkte til lakering. Efter jeg indførte denne behandling har jeg aldrig oplevet problemer med afskalling.
Hvad gør I andre? Jeg vil meget gerne høre om flere erfaringer.
Henk
http://www.privatbanen.dk/
- H0, 2-skinne -
Klartsyn
Når Du er godt i gang med skivet, må jeg så komme forbi og se om det er mulig at samle det ??
Klarsyn
Odense N
Tjo. Jeg er så småt igang, og det er til at have med at gøre. Dog skal man ikke forvente at man hiver delene op ad kassen og bare limer løs. Der skal slibes en del for at få de større ting på plads. F.eks. styrhuset består af 4 store dele der limes sammen. De har alle en for "fyldig" baseplade som jeg har fræset væk med min Dremel. De skriver man kan bruge sandpapir, men så langt er mit liv vist ikke
Jeg har limet med sekundlim, og forstærket det med en tokomponent epoxylim, det holder fint.
Der er korrekt at der skal god rengøring til ind der males. Grundrens og så en opvaskebørste/pensel til de små steder er fint. og så rigelige mængder rent vand og lufttørring der duer
Hilsen Morten
Min flåde udvides:
Dette tog færgen kommer fra JK Modell i Aarhus.
Færgen sejler til de (fiktive, opfundet af mig) pladser Ringholm og Thyrø.
Gert (fra Holland)
Og min Danske coaster:
Da' Gert.
Den minder mig sjovt nok en hel del om en hollandsk coaster ved navn Noordborg - måske de kommer fra samme værft?
Dette er ikke overraskende, fordi min coaster er bygget med en Artitec kit.
PED
Hej Gert,
It is not just happening there -something is rotten in the state of Denmark. Nu har du jo lært dansk i mellemtiden:
Danmark har mistet alle fiskekuttere. Ikke kun på Fyn. Vi havde rigtig mange, men de er væk!
Det skyldes EU, kvoter og forskellige danske regeringers ønske om at være dukse i EU.
Endvidere tillader alle lande at man bruger store trawlere (fiske-fabrikker), som tager alt fra bunden og til overfladen.
Det er svært at stoppe, men man kan forhindre landing! De bruger alle kvoter, mens danske fiskere får støtte til at ophugge kuttere.
Det er en katastrofe, som ingen har forstået konsekvensen af. I alle havne er værftet, maskinværkstedet, ophalerbeddingen, netfabrikken, el-instalatøren og meget andet lukket.
Danmark har mistet alle coastere. Vi havde en kæmpe flåde, men alt er væk!
De danske politikere har tilladt lastbiler at hente varer på havnen gratis, men coastere skulle betale havne penge.
Ingen har taget ansvar og 10 skiftende danske trafikministre har intet gjort.
Det er det samme der er sket med jernbanerne.
Lobbyisterne har ødelagt al logisk trafikudvikling.
Gert, hvis du vil have dette indlæg på engelsk siger du til.
Venligst
per
Dansk Epoke 3 Märklin HO
Hej Per,
Tak for svar! Dansk er ikke noget problem. Jeg var nu mere end 20 gange i Danmark og læse dit sprog så ofte.
Jeg har ikke en hjemmeside, men på en hollandsk forum jeg har en egen tråd: http://forum.beneluxspoor.net/index.php/topic,50822.0.html
Det er bestemt trist, hvad der skete med den danske fiskeri.
I Nederlandene er der også stigende modstand mod EU.
De politiske partier, der modarbejder EU vil helt sikkert vinde ved næste valg.
Da' igen.
Det havde jeg næsten regnet ud.
Og jeg vil jo også have sådan en coaster - så stor var min panik, da jeg kunne se, at Artitec melder udsolgt - ScanHobby gør det også, og kan jo nok ikke skaffe flere fra Artitec, selvom de mere eller mindre skilter med det.
Gang i Google: Happy-Trains - det lyder som en dårlig forengskling af et fjernøstligt navn - var et af de få steder, hvor jeg stadig kunne finde den, og så endda på tilbud. Det bliver bedre endnu: Køb for € 150,- og få 5% rabat - det kræver blot køb for € 0,01 mere - eller køb for € 300,- og få 10% rabat. Jeg kom til at gøre det sidste, og fik rent faktisk 10% oveni tilbudsprisen.
Så med mindre man vil satse på, at Artitec laver en ny produktion, er det nok nu, man skal slå til, hvis man vil have denne prægtige model.
Da' igen.
Ja, det er trist - der er slet ikke det samme miljø tilbage på ret mange havne. Hvis man stadig vil se en fiskerihavn, der minder lidt om gamle dage, er der vist stadig en del gang i Hundested havn.
Men jeg synes, det er letkøbt at give EU skylden: Det er jo ikke kun fiskeriet, der er gået fra små både til kæmpe trawlere og store produktionsenheder - vi har næsten heller ikke noget håndværk tilbage, og småindustrien forsvinder også hastigt. Og ikke kun i Danmark - og ikke kun i EU: Det er jo en global tendens. Jeg så en opgørelse et sted, der viste, at der for vist 25 år siden var mere end 3.000 bagermestre i København - i dag er der under 40.
I min barndom havde Brabrand tre købmænd og Brugsen alene på hovedgaden - sammen med to slagtere og to bagere, en cykelsmed, et renseri, et parfumeri (der også solgte Heljan byggesæt), en rigtig smed (cykelsmedens bror - de kunne ikke udstå hinanden), en boghandler, en skomager - jeg kunne blive ved. I dag er der næsten intet tilbage.
Hvor finder man i dag en rigtig smed? Eller en skiltemaler - jeg taler ikke om udskårne klisterbogstaver? Eller den lille snedker? Vi gik på forchromningsanstalten og fik forchromet eller bruneret vores knallertdele - hvor findes det i dag?
Så, ja, det er meget trist, at næsten hele fiskerimiljøet et væk: Men jeg nægter at gå med til, at det er på grund af en speciel hetz mod netop fiskerne - det er blot nok et udslag af en udvikling, der er ved at ændre ihvertfald hele den vestlige verden.
Hvor er min skrædder? Og hattemageren? (Der er vist een eller to af sidstnævnte tilbage i hele Danmark)
Hej Lars,
Hvis jeg var dig, ville jeg købe nu. Ny produktion kan tage år.
Det er faktisk en smuk model!
Da' Gert.
Du må øve dig lidt mere på dansk: Jeg HAR købt - og det står der også i min tekst, hvis man læser den rigtigt.
Faktisk kom jeg til at købe 14 forskellige Artitec sæt nu, der var god rabat på - men det må du ikke sige til nogen!
Ups! Undskyld!
14 forskellige Artitec sæt? Hvad vil du bygge?
Da' igen-igen.
Det behøver du ikke undskylde - du er imponerende god til dansk. Hvis bare mit hollandske...
Til min havn:
Den er godt nok bygget til trafik på Rhinen - men selv om den ikke er oceangående, kan den sagtens snige sig rundt i de indre, danske farvande. Og det gjorde de.
Har et par stykker - men det er ikke nok!
Robåde kan jeg (næsten) heller ikke få nok af.
Turbåde både var og er meget almindelige på Limfjorden.
Den må jeg bare have liggende i havnen.
Hertil et lille sæt med tre færdigt malede robåde - jeg kan som sagt ikke få nok.
Til min købstad:
Disse facader passer fint til en bagvæg i min købstad, hvor de gerne skal være opført omkring sidste århundredeskifte. Jeg får måske ikke brug for dem alle, men de er meget svære at skaffe i Danmark, og med de priser, jeg har fået dem til her, tog jeg dem alle med. De er trods alt nede i omkring 60,- kr. pr. stk.
Endeligt en bygning, jeg håber at kunne passe ind i mit fiskerihavnemiljø:
Det har kun et enkelt vindue på den anden side og er klart nok beregnet til at stå op mod f.eks. en banelinie: I mit tilfælde tænker jeg på at placere det op ad en banedæmning.
Som det allersidste:
De er helt perfekte til et dansk husmandssted.
Var det svar nok?
Ha ha! Bestemt. Men dette hus er typisk hollandsk...
Hvis du har problemer med at købe visse Artitec-produkter, så kan jeg nok hjælpe.
Nu skal jeg så igen passe på med sproget: Du skriver, at ET hus er typisk hollandsk - men ikke hvilket. Jeg tror dog, at du mener, at DISSE huse er typisk hollandske - dvs. dem alle?
Du har naturligvis ret, men de kan nu relativt nemt fordanskes til noget typisk dansk - det er mest et spørgsmål om at fjerne noget pynt fra facaderne, skifte tagbelægning og lidt andet, så er de ret tæt på. Den første facade - den lyseblå i to etager - kunne være taget lige ud af Matadors Korsbæk (Roskilde i virkeligheden). Og da der samtidigt er nogle resinkopier på vej af de "rigtige" bygninger fra Korsbæk, kunne de fint bruges sammen. De er endnu på udviklingsstadiet, men jeg har set prototyperne - og det ser meget lovende ud.
Jeg ville her gerne have henvist til Google Streetview, men de har desværre ikke været på besøg i de mindre, danske byer, så købstadsmiljøer som Skive og Lemvig, jeg ellers gerne ville henvise til, må man søge billeder af på anden vis.
Men jeg kan citere Wikipedia, der om Skive skriver "De fleste huse i bykernen er opført fra 1880-1914...", og det er de fleste af de byhuse, jeg her har valgt, vist også.
Lemvig er meget gammel og nævnes første gang i 1234. Lemvig Museum skriver:
I 1800-tallet voksede byen. Den første fremgangsperiode kom efter at der i 1825 blev slået hul på Limfjordstangen. Købmændene købte skibe, der sejlede til England og til Hamburg. Alle mennesker fik råd til at bygge nye huse. Det var bygninger som for eksempel Vesterhus, hvor Lemvig Museum nu holder til. I 1879 kom der jernbane fra Lemvig til Vemb og derfra videre mod Esbjerg. Det betød et nyt spring fremad for byens og egnens økonomi. Forretningsfolk begyndte at bygge store huse med tårne og karnapper omkring Torvet og i Vestergade.
Ellers kan man prøve at bruge Streetview til at gå rundt i de gamle bydele af Århus, Aalborg og Viborg: Man finder meget, der ligner disse bygninger.
Da jeg gerne vil lave en blanding af Skive, Struer, Lemvig, Thisted og Nykøbing Mors, håber jeg, jeg er på rette vej.
Jeg har skam også tænkt på dig som sidste nødløsning flere gange.
Men denne gang klarede jeg det selv - så kan jeg måske bruge dig en anden gang. Jeg fik alle de ovenstående Artitec produkter for tilsammen € 457,01 incl. forsendelse til Danmark - det er ca. 3.425,- kr. Coasteren alene koster 1.399,- kr. i Danmark excl. forsendelse.
Jeg mente virkelig et bestemt hus:
Lad du ser et billede, hvis du har bygget og fordansket dette kit?
I Struer og Lemvig jeg har været. Thisted, Skive og Nykøbing Mors vil helt sikkert besøge igen.
Jeg har redigeret lidt i denne tråd: Såvel jeg som Gert havde linket direkte til billeder af Artitecs modeller på Artitecs hjemmeside. Det kan man åbenbart ikke - billederne "fungerer" ikke, med mindre man har været inde for at se dem på Artitecs egen hjemmeside først. Derfor har hverken Gert eller jeg opdaget problemet - man går jo naturligt nok ind på siden for at finde billederne.
Men nu er der begyndt at dukke klager op over de manglende billeder, så jeg undskylder min dovenskab og har nu lagt billederne korrekt på Sporskiftet, så de ikke forsvinder igen. Det understreger nok engang, at man skal være meget forsigtig, hvis man linker til eksterne billeder - de har det med at forsvinde over tid!
Helt klar. Derfor fortrinsvis egne billeder.
Seneste nyt fra mig: Jeg har fundet et firma, der kan udskrive på silke.
Jeg har tænkt at give mine skibe danske flag.
Det lyder rigtig smart! Sætter du ikke et link på til firmaet? Straks jeg så din ide med at skrive på silke kom jeg til at tænke på pressenninger til f.eks. Tuborg og Carlsberg øl-biler!
Mvh,
Peter W
Der er to muligheder: self-print eller til udskrivning.
Hvis du ønsker at gøre det selv, du har brug for det: http://www.modelbouwshopnederland.nl/a-23828927/a4-inkjet-supplies/a4-vel-zijde/
Dette firma har i øvrigt udskrives bomuld. Silke er speciel for flag.
Du kan også oprette dine egne flag: http://www.modelbouwshopnederland.nl/a-2013869/vlaggen-flags/vlag-naar-uw-keuze-400-046/
Og jeg har også et spørgsmål mig selv igen: Er det obligatorisk at have i Danmark et horn ombord?
