Kresten
Problem med firmware opdatering af Loksound V3
Jeg har klaget min nød til både ESU-support og Loksound-gruppen på Yahoo, men hidtil uden held. Derfor forsøger jeg nu her - beklager det lange indlæg.
Kort fortalt har jeg nu smadret (ved ikke, om de kan reddes, men hvis det lykkes for mig at loade firmware'n på et tidspunkt, bør de vel virke) 2 styks Loksound V3 dekodere i et forsøg på opgradering til V3.5 vha. den pakke, der ligger på ESU's webside.
Beskrivelsen af mit problem er her (på dårligt skoleengelsk aht. det internationale publikum på andre fora) - er der nogen, der har et forslag til, hvordan jeg kan komme videre eller hvad jeg ellers kan forsøge:
I have tried twice, with two different decoders, to firmware upgradefrom V3 to V3.5. None of the updates worked, and I fear I have nowdestroyed 2 decoders.I am aware of ESU's warranty disclaimer, but it puzzles me that I haveexperienced exactly the same error (errormsg is not very informative,though - much like the standard Windows error screens - so it might bedifferent internal errors in the update function).:"I have now destroyed my second Loksound V3 during the V3.5-firmwareupgrade process using the LokSoundFirmwareUpdate_November_2008_02.zip-download from the ESU website.Although I am aware of the official warranty disclaimer, I'm pretty suresomething is wrong in the update program - or the supplied firmwarefile. I've been working in the IT-industry for 20+ years and never hadproblems regarding firmware-, microcode-, bios-, andmachinecode-upgrades on neither large servers nor PC's. But this puzzlesme (problem is exactly the same for both decoders):I have connected: PC -> LokProgrammer -> Profi-Prüfstand -> Loksounddecoder V3 with the 8 wires (not the violet AUX and not the brownspeaker-wires, which are connected to the decoder).When I start the upgrade, the decoder firmware is recognized (the firsttime) and the SW-level is lower than the displayed SW-level of theupdate. When I press the upgrade-button, the process start and after5-10 seconds I get the errormsg "An error occurred. Please try again".Trying again tells me, that there is no firmware in the decoder, theupgrade starts, but same errormsg.I can still read/write the CV's from the decoder with LokProgrammer(which to me means, that the electrical connection is OK), only the sizeof flash memory cannot be established. The virtual driver does notfunction either.I have ensured a very firm and stable electrical connection - so this iscannot be the problem.I am running WinXP. LokProgrammer is - according to the inside - V3.5with the number 00407-03114, Decoder tester is "Decoderteststand_v31". Ihave not got the original box from my decoder, but it is labelled "410"on one label and "45/05/08" on the other label.Both my LokProgrammer and the test-stand works perfectly with all myother ESU decoders.Please advise - what else can I try ? What can I do differently ? Whatcan be the problem ?"
Kresten
Busk
Hej Kresten
Jeg havde samme fejl i forbindelse med opdatering af lyd, indtil jeg geninstallerede USB driveren som ligger på installations CD'en. Før det havde jeg forsøgt alverdens gode råd og hjælpsomme folks vejledninger, sågar ESU's hotline, uden held. Selv om det rent computermæssigt lyder underligt at man kan have kontakt til Lokprog. og aflæse cv værdier, for det kunne jeg godt, men ikke indlæse lyden :?
VH Torben
Kresten
Hej Busk,
tak for dit svar. Men for at jeg overhovedet kunne få LokProgrammer til at virke, måtte jeg finde en nyere udgave af Com-til-USB Prolific driver på internet. Den, som ESU stillede til rådighed, var alt for ustabil. Efter at have installeret den nye version, kører det OK.
Så den vej har jeg desværre været ude af - uden bedre resultat... Sad
Kresten
Busk
Hm... Har du ikke en bekendt i din nærhed der også har en lokprogrammer, så prøv hos ham og se om din decoder vil, jeg tænker, kan der være noget software misk-mask? Jeg ved godt dette er ude i det famlende :?
Kresten
Jo - men jeg befinder mig sandelig også i "det famlende område". Desværre kender jeg ingen andre, der har en LokProgrammer. Og min LokProgrammer har fungeret udmærket til alt muligt andet, såøh... Men ingenting skal naturligvis udelukkes.
Er der andre, der har erfaringer med LokSound firnware opgraderinger ? I så fald hvilke ?
Kresten
Voller
"Kresten" skrev:
Er der andre, der har erfaringer med LokSound firnware opgraderinger?
Jeg har brugt det et par gange. Det har ikke givet mig nævneværdige problemer, og da slet ikke af den kaliber du beskriver.
Det skal siges, at jeg ikke benytter en seriel/USB-konverter. Jeg bruger min LokProgrammer via en seriel/COM-port. Det fungerer fint, men jeg ved godt seriel-porte kan være en mangelvare på nyere computere.
Det var måske et forsøg værd?
Mvh. Thomas.
Digital treskinnedrift
http://modeltog.voller.dk
Kresten
Jeg har selv tænkt på USB/COM-konverteringen som mulig fejlkilde. Jeg prøver at få audiens på min søns stationære - den har ihvertfald en god gammeldaws seriel port - som jo ikke findes på vores moderne bærbare...
Tak for tipset Smile
Kresten
fkm
IT-Systemadministrator
Hej !
Jeg havde selv mange problemer med at benytte LokProgrammer via USB - mange kommunikationsfejl. COM virker helt uden fejl.
Teknisk set kan det være ligegyldigt hvilken port man benytter, da LokSounden ikke kan modtage data hurtigere fordi man benytter USB.
Flemming
Kresten
Jeg har som svar på min mail til ESU fået tilsendt en december beta-version af firmware-updater fra ESU Support her til morgen (jeg er virkelig imponeret over ESU's support - det er 2. eller 3. gang, jeg skriver til dem og der er prompte svar hver gang. Sidste gang fik jeg også en beta-version af LokProgrammer, som løste mit daværende problem. Det er næsten lis'så godt som Klaus i Hammel Shock).
Den får jeg prøvet i aften (altså beta-versionen) ligesom jeg forhåbentlig også får afprøvet den serielle løsning.
Kresten
Kresten
Har desværre netop måttet skrive til ESU, at december betaversionen heller ikke virkede på min dekoder. Så nu er der USB/COM tilbage at prøve :?
Kresten
Kresten
Ja - enig. Men jeg ved fra bios- og microcode opgraderinger, at forbindelsens stabilitet er meget afgørende. Der tillades ikke mange transmissionsfejl før det går galt. Og det er vel lidt det samme, der sker her - bare i betydeligt mindre målestok....
Kresten
Lau82
Hej Kresten.
Jeg arbejder til dagligt hos http://www.bms.dk hvor jeg hovedsageligt laver lifte, (sammenhæng kommer nu) vi bruger et program kaldet WEBgpi til at få kontakt til JLG´s lifte, vi fik tilsendt 6 stk. USB-COM port inkl driver cdér til hele pisset.
ALLE værkstederne, har nu anskaffet sig ældre bærbar maskiner til dette formål udenlukkende, simpelthen pga. problemer med USB-COM port ustabilitet.
Rigtig rigtig mange COM via USB kort (stik) virker ikke ordenligt, et problem som f.eks. via google, får 1690 svar frem, alle med problemer.
Hvis du kan komme i kontakt via. COM port på den en eller anden måde (evt. hos en ven for at bare teste det) så prøv at se om det ikke gør HELE forskellen i sig selv.
3 Skinne drift med MS2 - Epoke IV & Epoke V - Dansk & Tysk matriale
Erik 1:87
Softwareingeniør
Vestfyn
Hej Kresten
Jeg arbejder til daglig med bl.a. seriel kommunikation (COM / RS232). Vi foretrækker et indstikskort til PCMCIA (PCMCIA til COM) f.eks. Multiport. Det har vist sig at være mere stabilt end USB/COM. Desværre er disse kort ikke helt billige og så kræver det jo lige at man har PCMCIA port i PC'en.
Søg først audiens hos sønnike. Virker det her kan du overveje ovenstående, ellers skal fejlen jo nok søges anden steds. Fortsat god jagt.
Vi føler med dig. :roll:
Hilsen Erik, My 1 2 87.dk
fkm
Og lige en sidste detalje: Skinnerne er vel rene? Strømoptag på lokomotivet skal også være OK - er der fejl på strømmen eller "huller" i den, så går det også galt.
Flemming
Kresten
Der er hverken skinner eller lokomotiver involveret i det her: PC -> LokProgrammer -> LokPilot tester -> dekoder. Det er også derfor, jeg ikke har mistanke til den elektriske forbindelse, men til data transmissionen......
Kresten
lgh
Skiltemager/Grafiker
Davser Laughing out loud
Hov, det er ikke din LokPilot tester der driller..??? bare en tanke.
Lennert
Far kører tog, bygger og hygger.....
Hvad gør Bill Gates når bilen strejker??......Lukker alle vinduer og genstarter!!!
Kresten
Jeg tror det ikke - har prøvet den med masser af andre dekodere og aldrig haft problemer. Desuden startede mit nuværende problem, da dekoderen stadig sad i lokomotivet. For at være helt sikker på en stabil forbindelse, afmonterede jeg den og satte den i stedet i testeren... - en vane fra bios-opdatering af min bærbare PC: Ud af port-replikatoren og direkte strømforbindelse... Smile
Kresten
Kresten
Så lykkedes det. Sgu!!!
Jeg af- og re-installerede forskellige USB/RS232 drivere, jeg fandt på nettet uden held. ESU support bad mig om helt at fjerne alle drivere og re-installere den oprindelige driver, som var leveret med LokProgrammer - uden(!) at LokProgrammer var tilsluttet.
Da jeg i sin tid installerede LokProgrammer, kunne jeg ikke få den leverede driver til at fungere, og havde fundet en nyere version på nettet som jeg brugte uden problemer. Altså indtil jeg kom til firmware-update, åbenbart.
Jeg kan ærligt talt ikke huske min oprindelige installations-rækkefølge, men det er åbenbart vigtigt, at driveren installeres FØR USB-devicen.
Så nu er min LokSound V3 opgraderet til V3.5 - oveikøbet uden tab af hverken CV'er eller lyd.
Tak for hjælpen og gode forslag til alle. Laughing out loud Laughing out loud Laughing out loud
Kresten
BlackChart
Skanderborg
Det er da helt normal praksis at når du skal installere driver til en ny USB enhed, så skal driveren installeres FØR enheden tilsluttes...
Morten Trab
Trab.dk - Din Arduino Leverandør
http://www.trab.dk
Møtrik
har du den nyeste firmware til programmeren?
Kresten
Jep - alt firmware er nyeste version - men nu virker det jo osse... Laughing out loud
Kresten
